How do I Add Smartnet Contract to SNTC portal
JAMES LOPEZ
We have six active Smartnet contracts however only four are shown within SNTC.   How do I add the other two?
tfitch
Hello James,
The contracts are reflected in the portal against the devices that they cover under those contracts. You do not need to add contracts to the SNTC portal.
If you believe a device is covered but this is not reflected in the portal correctly then please supply a couple of the necessary serial numbers and we can check.
Regards, Tim
Hi Tim,
Can you please check the following devices?
FDO20361DNN
JMX2023L02X
JMX193180FA
FXS1931Q5G0
FXS1931Q54T
FOC1950Z1LB
FGL200440R8
FGL200440R9
Jim
Hi Jim,
I have checked the serial numbers. None are in the inventory for your Company name.  I cannot see if the Inventory Insight Reports helps as you would need to check using hostname. I check the SNTC Supported Device list and not all are supported so would not show for that reason.
Regards, Tim
Serial Number  Contract CRParty PID SNTC Support
FDO20361DNN ending 223 Company Name Ending in INC C1-N9K-C9372PX-E NOT SUPPORTED in SNTC
JMX2023L02X ending 223 Company Name Ending in INC ASA5585-S10X-K9 NOT SUPPORTED in SNTC
JMX193180FA ending 223 Company Name Ending in INC ASA5585-S10-K8 NOT SUPPORTED in SNTC
FXS1931Q5G0 ending071 Company Name Ending in UK ASR1001-X Supported in SNTC
FXS1931Q54T ending071 Company Name Ending in UK ASR1001-X Supported in SNTC
FOC1950Z1LB ending065 Company Name Ending in UK WS-C2960X-48TS-L Supported in SNTC
FGL200440R8 ending065 Company Name Ending in UK ASA5545-K9 NOT SUPPORTED in SNTC
FGL200440R9 ending065 Company Name Ending in UK ASA5545-K9 NOT SUPPORTED in SNTC
