Log4j PSIRTs?
JSM92
Are there really no physical devices affected by Log4j?  Just noticing there are no PSIRTs in SNTC portal about it.
Chris Camplejohn
For the products supported in SNTC Portal, only ISE and NCS1004 are affected by log4j.  Rest of the SNTC Portal products which have Security Advisory automation are not affected.
vivekcha@cisco.com
Hope you are doing well!
We are looking into the issue and get back to you with updates.
Vivek Chauhan
Chris Camplejohn
