12-03-2016 09:11 AM
Has anyone experienced issues with Nexus devices not showing up in the portal? They are being discovered, but the collector says that they are being excluded. All the portal tells us is that they failed to be uploaded.
12-05-2016 06:32 AM
The collector is saying that the device is already being managed by a different IP address. If you look in the managed device list, you should see it listed under the IP address mentioned in the excluded message.
Lynden
12-06-2016 09:57 AM
There are no devices in the portal under the IP address that the collector referenced.
12-06-2016 01:23 PM
I've seen a bug like this before. Reboot the entire server (don't just restart the CSPC services) and the blank entries should go away, and then you should be able to discover the device as normal.
Lynden
12-19-2016 10:54 AM
The devices in question are still not showing in the portal. Are there any other potential reasons why this might happen? One of the devices is showing up in the "not collected" list but has no suggested actions. The others are not even having that information populated.
01-05-2017 06:13 AM
What is the "not collected" list you are referring to? Is it on the portal or on the collector?
Lynden
