Problem upgrading CSP to version 2.6
When I try to load the upgrade patch file I got the following error on the screen:
Patch File Upload operation failed: /opt/cisco/ss/adminshell/applications/CSPC/webui/tmp/patches/jeos-20.0.0-1-lnx64andsp-3.0.7-0-0-lnx64.zip (No such file or directory)
What his mean, and, if possible, how I can fix it?
Thank you
2 Accepted Solutions
Lynden Price
If you run "show download" does it show that the patch was downloaded successfully?
What is the collector version? You can find this by running the "show version -d" command.
15 Replies 15
Lynden Price
I try to download the file using the GUI, and that is the message I got. The file is in my laptop, in the desktop.
What is the output you get from the "check update" command?
This command is not recognize in the command prompt of the VM server
This command is not recognize in the command prompt, no even using root user. In the GUI, in help, about, it said Cisco CSP collector 2.5 , with patch 2.5.1.6
What is the filename of the image you deployed?
SNTC-CSPC2.5.2.1-OVF10.ova
Could you SSH into the collector using the "admin" username? Those commands should be recognized in the admin shell. They will not work in the Linux command line.
Thank you for your help. This is the sh version -d command.
admin# sh version -d
Build-name : PSS CSPCServer 2.5.1.6
Package-type : ServicePack
Version : sp-3.0.6-0-0-lnx64
Component : Data Pack
Version : RP3.23_PSS
Component : CSPC SE Add-on
Version : 1.1
Component : CSPC Base
Version : 2.5.1.6
Package-type : JeOS
Version : jeos-3.0.6-0-lnx64
Component : Serviceability
Version : 1.0.9
Component : ConcsoTgw
Version : 1.4.6.2
Component : Jetty
Version : 7.1.0
Component : AdminShell
Version : 1.0
Component : Hardened CentOS
Version : 6.7 patch#0
I also did check update, below the results:
admin# check update
Connection with server for Software Updates is currently disabled.
Please use "conf server enable" command to enable it.
Command execution aborted because of above condition.
admin#
admin#
admin# conf server enable
This operation will enable connection with server for Software Updates.
CCO Id :
Invalid input - exiting the configuration
Are you sure you deployed "SNTC-CSPC2.5.2.1-OVF10.ova"? The output above shows the image as "PSS CSPCServer 2.5.1.6"
Lynden
That is the file I install first, them , when they were available, I apply the following patches, in the order they were apply:
- cspc_cp_2.5.1
-cspc_cp_2.5.1.4
-RP3.23_PSS
-cspc_cp_2.5.1.4
-cspc_cp_2.5.1.6
I think you may have accidentally installed the wrong patches. Those are the patch files for a PSS collector. Do you have the PSS service or SNTC? If you are using PSS, then you will need to deploy a PSS OVA, and then the patches should work.
I have SNTC.
So, what you suggest, remove all the current patches ?
