Problems with CSPC Collector-2.11-B-16_SHA1_signed.ova
stuartkendrick
Anyone else tried installing Collector-2.11-B-16_SHA1_signed.ova?
What I see:
1. VMWare ESXi identifies the cert as untrusted, during the OVA import process
2. And, once installed, it enters a reboot cycle, starting at the GRUB menu
- AlmaLinux (Shamrock Pampas Cat)
- Booting AlmaLinux
- osnoise:  Error registering osnoise!
- And then back to the GRUB menu
Anyone else?
--sk
10 Replies 10
adias
Be aware that CENTOS OS as you previously had known, is not longer available as developed product, the previous CSPC was based on that OS which EOL
1) The present OS is CENTOS Stream is a Red HAT version of that previous OS please see
https://en.wikipedia.org/wiki/CentOS_Stream
2) The present errors "- osnoise: Error registering osnoise!" shown on  deployment are cosmetic and not catastrophic and will be removed in future releases
3) VMware newer products flags any self-signed certificate and untrusted, but if they put the flag "ignore" you can proceed.
What version of ESXI host you have ?
VMWare ESXi v8.0.2
enrirami
Thank you for contacting Cisco.
Please send me in a private message the following information.
• Company name.
• Company address.
• CCOID.
• Email.
I will be attentive to your reply.
Kind Regards,
Enrique Ramirez
I have this problem too. Is there and solution?
adias
 Is you VMware version also 8? what specific problem you are referring to. since the author mentioned more than one.
VMware Version 8.
After load the ova to VMware. It takes minutes to start the VM and than it reboot continuously.
Here is some more information in the hope of help.
It is VMware ESXi, 7.0.3, 22348816 but please don't just say it has to be version 8. And then the whole thing doesn't work because it was due to something else.
akashcho
I am experiencing the same issue.
enrirami
ESXi running on host using AMD processor are affected, a bug has been created, you can subscribe and once resolved you will receive a notification.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwk20991
Our internal team is working on it, any progress can also be followed by subscribing the bug.
And now any resolution? Any progress? Workaround?
