06-29-2017 11:12 AM
Is there a way to remove Captcha? I thought this was for robot prevention. I'm not sure that is an issue on our internal network. It is more of a nuisance.
Solved! Go to Solution.
06-29-2017 12:08 PM
Hello Chris,
Unfortunately at this time there is no way to remove this security feature of the CSPC. We are working with our development teams to see if this feature can be optional in future releases to make it easier to use.
Thank you,
Jarrett
06-29-2017 12:08 PM
Hello Chris,
Thank you,
Jarrett
06-30-2017 03:35 AM
Thank you. That would be great if they could add that feature. I would understand adding a 2fa option, but not captcha.
