11-28-2016 12:12 PM
According To Lynden Price's setup guide he says the following
To generate an entitlement, go to the Smart Net Total Care portal: https://tools.cisco.com/smartservices/
Close out of any splash screens.
In the left pane, Select Library > All Collectors
Once the screen loads, select the Actions dropdown and choose to “Register a New CSPC”
11-28-2016 12:20 PM
Hi, Click the Back button (in the upper left hand corner of the portal page), and you should see a selection of different services that you have access to:
You currently have Partner Support Service selected. Choose Smart Net Total Care instead and it should show the information you are looking for.
Lynden
11-28-2016 12:28 PM
Thjanks for the swift Reply Lyndon. when I click the back button the otions I have are
Nothing else no Smart Net Total Care???
11-28-2016 12:40 PM
Why do i not have the Smart NET Total care TAB ?
Also what is the difference between selecting the collector from Partner Support Service or Smart Net Total Care ?
11-28-2016 02:29 PM
PSS and SNTC use different collectors to upload to different portals. So if you make a registration on the SNTC portal, it will upload to the SNTC portal, but won't send anything to the PSS portal, and vice versa.
In your case, it looks like you don't have access to the SNTC portal, which is where you will need to generate the entitlement I describe in my blog post. You'll need to get access to the SNTC portal first.
You can find help for doing that here:
https://supportforums.cisco.com/document/13086306/portal-access-troubleshooting
Lynden
