single collector, multiple services
cmarva
Level 4
Level 4
i have read over the document "CSPC - how to enable multiple services". It covers the registration part only. I have a lot of other questions regarding this. Basically, i'm wondering if i can register my CSPC with a service for a recent acquisition, who has their own CSPC, and get rid of theirs.
Has anyone tried, or is anyone using, a single collector with multiple services?
thanks
adias
please add the link of the document you mentioned on your post :
The example you are giving does not qualify as multiservice:
in your example it seems you want to make one collector to collect all devices. which you would only need to add those devices to your collector if they were reachable from your collector - and then they would  need to be onboarded the users of the other and they Portal instance would need to be decommissioned
If you cannot access the devices they have ( access list , firewall, routes and so on. ) you could simply create another certificate with a different inventory name on your portal instance and they can replace the certificate on their CSPC , this way that collector now would belong to your portal instance and you can see them distinctively by inventory name or combined by all . It seems this one would be more appropriately.  The users on their portal still would need to be migrated to your account and that portal be decommisioned
cmarva
Level 4
Level 4
the link is https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/Enabling-Multiple-Services-on-a-CSPC.pdf
well, eventually it would be one inventory. I will have to check and make sure that both inventories can be merged, there might be a non-compete or some other legal-ese stipulation that would prevent us from doing that. But my though was to see if we would be able to use one collector, registered to both sntc portals and collect and upload to the relevant portal. I guess i was wayyyyyy off with my understanding of the multi-service document. anyhow, at this point it's not a big deal. Thanks for the response
