01-19-2024 07:44 AM
In Smart Net total Care Portal https://services.cisco.com the portal was working after the onboard process. Was able to use the left menu to navigate between contracts and inventory from what CSPC was collecting and uploading. Now the page is loaded, but there is no information being displayed under any menu option. Called TAC, and they informed me that SNTC support is only given by this forum. Could someone help me?
Also, I have tried to access the portal on multiple computers and browsers, on different service providers. I get the same outcome.
Solved! Go to Solution.
01-31-2024 12:31 PM
Solution: Cisco recommends using Firefox, and not Chrome or IE. Verified that this is working via firefox. Thank you
This bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh61855, you can subscribe and receive notification about
the Portal loading status.
01-19-2024 12:34 PM - edited 01-19-2024 12:39 PM
Hello Tim, Thank you for contacting Cisco and Global CX - Smart Services
Support Team.
I understood that the SNTC Portal is showing any data information after collecting and uploading from the CSCP Collector.
Can you please provide the next details by internal message:
- Company Name in the SNTC Portal:
- Inventory Name:
- CSPC ID:
- CSPC Version:
01-22-2024 06:18 AM
Do you have an email that I can send this information too. I don't feel comfortable making this information public.
01-22-2024 12:19 AM
I've been having this same issue for quite a while now. I've actually given up on the portal since I waste more time trying to access data than it's actually worth. The idea of the collector and portal is great, and I wish it really worked well. It however is not worth the hassle of trying to keep the collectors working and updated, and to retrieve the data from the portal.
I hope someone from Cisco decides to put some effort into making this portal usable.
01-22-2024 06:19 AM
It is sad to see products from Cisco not being maintained.
01-22-2024 09:18 AM
Hello Tim,
I do apologize for any inconveniences.
To send me information by private messages, please click on my user name as you can see in the picture below
After this, the system will open a new window as you can see below, please select the private message option on the right side of your screen, and send as you can see in the picture below.
01-30-2024 09:04 AM
losorioj, I sent you a private message with the info.
01-30-2024 10:16 AM
losorioj,
I also sent you a private message with the requested info
01-31-2024 12:31 PM
03-06-2024 04:29 AM
Hello @Tim Rogers I'm facing the same problem, and even in Firefox "incognito mode" is not working. I would like to know if they identified the source of the problem, and if there is any expectation of normalization?
