SNTC Access for EoX and Product Information API
shrimpcracker
Can anyone please show me some direction to get EoX and Product Information API access?
Our CE manager guided me to register to CX cloud thinking it would allow to request api access.
However, we're told that CX cloud currently does not support the APIs.
Please advise.
Thank you.
Chris Camplejohn
Thanks for sharing the details.  Definitely access to CX Cloud will not solve this for you.  The documentation does say you need access to SNTC Portal, but when I asked about this previously, I was informed that was not required.  Recommend you reach out to the support alias for those APIs:  supportapis-help@cisco.com
Please report back what you find out.
10 Replies 10
Best place to start is here https://developer.cisco.com/docs/support-apis/
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Chris Camplejohn
The post above is correct.  You do not need to have SNTC Portal or CX Cloud for the support APIs.  If you want to have API access to your company's data in CX Cloud, that is currently not available, but is coming later this year.  The Support APIs are "generic" APIs, meaning they are not specific to your company data.  i.e. You pass in Product IDs and get back EOX information.  If you create a CX Cloud account and populate with your company's assets, the EOX and Product Information is automatically present in the portal and you can export it to CSV.  That same data will be available via API in the future.
shrimpcracker
Yes, I understand they're generic api. However, I don't think it's allowed unless you're provisioned for api access.
When I try to add more api to generate key for EoX and Product Information on Cisco API Console page, I don't see them as choice. Only followings are available for me to choose. When I shared this to my CE manager, she thought it's available since SNTC portal is migrating to CX Cloud. I guess I should see EoX and Product Information listed here to get a key to be used in a script?
Corona API : Corona
Cisco PSIRT openVuln API
Cisco Carlsbad IT QA : Cisco Carlsbad IT QA
Cisco On Demand CHIDS API : Cisco On Demand CHIDS API
CEEM API : CEEM API
Datafoundation-POE : Datafoundation-POE
HelloCommerce API : HelloCommerce API
Workforce Mohit
Hello API
Software Suggestion API V2
Chris Camplejohn
I've sent several emails to them including one from last friday and this morning. Still waiting to hear back from them.
Not sure if anyone in this community have direct relationship with the team....
I also reached out and will try to get an answer.
shrimpcracker
Chris,
Thank you for helping me out on this. Got help from api support group using the email address after several email sent out.
Chris Camplejohn
Great to hear.  I am continuing to work with them to solve it generically for everyone.  Thank you for your patience and helping to blaze the trail for the solution.
I have a Cisco account with my contracts, I see my products and support.
I needed to create an API to have Cisco's EOL, EOS, I think it is necessary to create an EOX API. In the portal https://apiconsole.cisco.com, when I go to MY Apps and Keys and create a new one, the EIOX API does not appear??? They appear generic, which is not 1-api.png2 api.png
what I am looking for, what do I have to dohich is not what I am looking for, what do I have to do ?1-api.png2 api.png
@npimentelpereira Recommend you reach out to the support alias for those APIs:  supportapis-help@cisco.com
