SNTC Not Internally Consistent with Inventory and Alerting
twylyghtcisco
For whatever reason, it would seem the below thread is considered closed:
https://community.cisco.com/t5/smart-net-total-care-portal-and/missing-data-with-latest-uploads/m-p/3748055
and CSCvn48271 is being considered fixed.  Per the request at the end of the aforementioned thread here is the examples of what is continuing to happen:
Upload goes through:
Example of one alert (Software EoX for 15.5(3)M) indicates 640 devices for said alert:
Filter on said software version denotes 1112 devices running this code:
Manually run reports per suggested workaround in CSCvn48271:
Data reflects the same number as the Alerts page:
No other software alerts show up on the portal page, but manual report indicates another 110 devices with Software EoX Alerts:
CSPC appliance indicates 1117 devices with this code is reachable as of its last collection:
EDIT:  The reason for the discrepancy between the CSPC Appliance and Inventory counts is because we have 5 devices that are running 15.5(3) code that isn't 15.5(3)M4a (the filter I used in the SNTC portal display).
brawall
Hey twylyghtcisco,
It appears the fix for CSCvn48271 has not been pushed to production yet. Currently the fix is being tested and when ready will be run in our production environment. I will keep you posted when that has occurred.
Thank you,
Brandon
brawall
Hey twylyghtcisco,
Thank you,
Brandon
Thank you sir.
Following the latest discovery of our inventory, it looks like the hardware portion of SmartNet alerting is re-aligned.  However, I am seeing some double-entries of our software now.  I will open another thread for that issue.
For now, the hardware alerting appears to be functioning as needed.  My thanks for the updates.
