04-06-2016 10:26 AM
When I log into the SNTC Dashboard and I navigate to Administration the only option I have is "All Collectors", can you tell me how I can get access to the other menu options like Upload Processing, File Import, Etc?
Greg
Solved! Go to Solution.
04-06-2016 12:17 PM
Hi Greg,
Have you created an inventory yet (either by importing a CSV or by setting up a collector)? The remaining menu items do not usually display until there is an inventory in place.
Nathalie
04-06-2016 11:43 AM
Hi Greg,
Some features are only available to Customer Admin roles versus Customer User roles. If you dont mind me asking, are you a Customer Admin or Customer User?
Bobby
04-07-2016 03:36 AM
Thanks for your response! I did check after and verified that I'm listed as a customer administration. I think its the fact that my upload is taking a long time to process.
Thanks Again!
Greg
04-06-2016 12:17 PM
Hi Greg,
Nathalie
04-07-2016 03:35 AM
Thanks for your reply. I think this might be the case. I had a separate question posted on the upload and I found out its actually still be processed. So I am thinking that is the issue.
Greg
