SOLVED: Problem after upgrade to 2.7.3.1!!!
shansson
I have upgraded my collector from 2.7.2.5 to 2.7.3.1. (GUI upgrade).
The upgrade itself seems to have worked.
But when I log in to the GUI I end up in the intial configuration wizard. And it looks like my settings has been lost. GUI/SSH  user and password are still the same as before the upgrade.
Looking in CLI, timezone, hostname, DNS and so on are still there.
Is all my setup lost? Can I get pass this wizard somehow? Or do I have to reconfigure everything again?
And yes. I did not do a backup of my settings before upgrade... :-(
Solved. I needed to fill in the "install" part of the wizard screen again for some reason. Then everything seems to be as before.
Sven
Hello Sven,
We're happy to hear the issue was so easily resolved.
Cheers,
Cheri
