SSHv2 Key Exchange Method on CSPC
Does anyone know the SSH Key Exchanges CSPC supports and if there is a way to select more options?  Trying to SSH to a Cisco Firepower from the collector and I believe it is failing because of the key exchanges.  I know my credentials work because I logged into the firepower from SecureCRT, but I had to check an additional key exchanges to get it to work.  These are the key exchange methods that the Firewall admin has enabled:
curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512
Thank you,
Mike
5 Replies 5
agkher
Hi Mike,
My name is Agrim Kher and I will be handling your request.
Please provide the screenshot of the error you are facing while trying to connect to the cisco firepower device.
Agrim
Hello Agrim,
I am unsure where to get you the screenshot.  I can't seem to find any detail log showing the SSH attempt, just that it failed.
Mike
Agrim,
Is there a way to see on the server what key exchange methods are in use?  The firepower uses stronger methods and I think it is possible the CSPC either doesn't support them or they need to be enabled.
Thank you
Hi Micheal,
Please let me know if you trying to ssh to a device from the collector.
If yes, please let me know the command you are using.
Agrim
Hi Agrim,
No, I am not trying to SSH from the collector.  It is part of the data collection process.  However, after looking into this further, i believe the issue is with Cisco firewalls in general, as all of the firewalls I have in the collector fail CLI.  Thank you for your responses, I no longer need assistance with this.
Thank you
