SSL Cert Configuration
Freddie Eisa
I'm trying to setup SSL for the collector. Where do you run the openssl commands from? When i try on the CLI the command is not found,
5 Replies 5
Jarrett Pomeroy
Hello Freddie Eisa,
Would you be able to provide some more details on what you're trying to do?  Currently we do not have any openssl based commands that are supported.
Thank you,
Jarrett
Im trying to add the SAN name for a certificate for this device. Logging in as root.
Hello Freddie,
You can find our certificate import details available on the CSPC User Guide starting on page G-1.
Thank you,
Jarrett
The section you mention (Appendix G) says to run OpenSSL from the CSPC CLI.  If you try to run OpenSSL as admin, it says the command is not available.
This commands must be run under the root user account, please note that you must connect to the user colllectorlogin first and the su to root as mentioned belowrootuserconfig.jpg
