10-09-2020 04:46 AM
I appear to be stuck in a login loop. After recently getting my CCO changed I lost access to all company access.
Most of this has now been restored however I cannot access the SNTC Portal.
When I first login it appears as if its about to connect to the portal but then reverts back to the splash screen - Get Access to Smart Services Connection Now.
I then select Register and then the page changes to say Redirecting: It appears that you already have access to Smart Net Total Care Portal. You will be redirected in 10 secs. It then take me back to the plash screen. Happy to supply screen shots.
Can someone in Cisco help?
Paul
Solved! Go to Solution.
10-09-2020 09:19 AM
10-09-2020 06:07 AM
I've reviewed the status of your CCO ID to your SNTC registration and completed a re-sync. Can you attempt to access the portal not and confirm?
10-09-2020 09:19 AM
Justin,
I am in great. Thank you.
Paul
10-29-2020 07:41 AM
I am facing the same login loop issue. Please are you able to do a re-sync on my SNTC registration as well?
Thanks.
Rahul
10-30-2020 06:54 AM
