support in malta
smonpier1
Hi All,
I would like to know if the cisco smartnet 24x7x4 onsite is available in the country Malta.
https://en.wikipedia.org/wiki/Malta
Sony
You can determine availability by checking the Service Availability Matrix.
https://samccx.cloudapps.cisco.com/apidc/sam/search.do
Leo Laohoo
If you purchased SmartNet then it will be covered.
thanks for the feedback. will check the link
tnewell
Sony - check the Service Availability Matrix. It helps to have the postal code and product family available.https://samccx.cloudapps.cisco.com/apidc/sam/search.do
