Unable to import CSV file in SNTC
clouedin
I'm unabled to import .csv file in SNTC. Each time I try, I've got the error :
 "Import Errors: Operation could not be complete. [Unable to perform the operation = File Import failed. Error in CSV headers.]"
Here is my .CSV format :
Hostname,IPAddress,SerialNumber,ProductID,MACAddress,sysLocation,SoftwareType,SoftwareVersion,
host1,x.x.x.x,ABC123,ABC123,,,,
Could you please help me to find what I'm doing wrong ?
Thank you
Suchita Shewale
Hey Celine,
It appears the headers from your CSV are incorrect.
I see there is one extra comma at the end of the header, highlighted below -
Please remember to remove both row 2 and column I when submitting CSV file.
Give this a try and let me know if you still run into issues.
Suchita
Suchita Shewale
Hey Celine,
Suchita
Hi Suchita,
Thanks it was my problem!
regards
Céline
