Unable to upgrade using Admin Shell
bbienaimee44
Hello All,
I am running into problems in upgrading to software version 2.7.4 via Admin Shell. I am able to login with the collectorlogin user ID, and switch to root using the su - command, but when I enter "download sp-30.0.4-0-0-lnx64" I get the message:
-bash: download: command not found
I did some research and I read an article that my path file may need to be added before entering this command and in order to locate the file path to enter the "echo $PATH" command.
After entering the command I get the following:
/usr/xpg4/bin:/usr/xpg4/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/s bin:/bin:/opt/vmware/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin:/opt/cisco /ss/adminshell/applications/CSPC/cli/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/loca l/bin:/opt/cisco/ss/adminshell/applications/CSPC/cli/bin:/root/bin
At this point I am clueless as to how I can proceed. Any help/guidance would be great!
Bobby
brawall
Bobby,
LCM upgrade commands need to be run from the admin shell instead of bash. Please try logging in with your CLI admin credentials instead of collectorlogin and then issuing the download command.
You could also get to the admin shell by issuing #su admin while logged in as the root user.
Thank you,
brawall
Bobby,
Thank you,
