Update to 2.7.4 stuck at Apply-in-Progress
ccrfranck
Version Number : sp-30.0.4-0-0-lnx64
Status : Apply-in-progress
Start Time : Apr/09/2018 16:38:16
End Time : -
I've already tried to set the status as "apply-failed" to restart the installation process but without any result.
Any idea?
Thank you.
Renaud
5 Replies 5
Supriya Patel
Hi Renaud,
What is the current version of collector (please provide 'show version -d' output? Did you receive any error while trying to set to 'apply-failed' status? If any error, please share.
Supriya
Here is:
admin# show ver -D
        Build-name   : Collection Platform Software 2.7.3.2
ij> connect 'jdbc:derby://localhost:1527/opt/LCM/info/updates; create=true;user=app;password=password';
ij> ij(CONNECTION1)> update updates set PACKAGE_STATUS = 'Applyfailed' where PACKAGE_STATUS = 'Apply-inprogress';
0 rows inserted/updated/deleted
WARNING 02000: No row was found for FETCH, UPDATE or DELETE; or the result of a query is an empty table.
ij(CONNECTION1)>
Best regards.
Renaud
Can you please check and see if the patch files seem to have been downloaded successfully?
From a root username, you can run the below commands:
'ls -alrth /opt/LCM/tmp/'
Thank you,
Jarrett
(I've made a mistake, I accept this post as solution, I don't know if anyone can chage that).
There are these files in the directory:
-rw-r--r--. 1 casuser casusers 1.1G Apr  9 16:29 sp-30.0.4-0-0-lnx64-package.zip
-rw-r--r--. 1 casuser casusers 340M Apr  9 16:40 sp-30.0.4-0-0-lnx64.zip
Best Regards.
Renaud
Thanks Renaud.
I will send you a private message with some additional commands we can try to start the upgrade process.
Thank you,
Jarrett
