03-17-2023 01:45 PM
I am running 2.9. I was going to upgrade to 2.9.1.5 but apparently support for that is going away. I looked up the upgrade process for going from 2.9 to 2.10.x but it appears that you can't upgrade - it's a whole new install. Is that true? What is the actual upgrade process (I'm running on a VMWare VM) and how do I preserve and restore my databases of devices, credentials, etc., etc.?
Solved! Go to Solution.
03-17-2023 01:53 PM
yes you need to have new installation of smart collect 2.10 and Migrate the data.
03-17-2023 01:53 PM
03-23-2023 08:33 AM
What process do I follow for migrating the data?
03-23-2023 12:05 PM
Do I have to install Collector-2.10.0.1-B-7.ova (I'm using it on a VM) and then upgrade to 2.10.0.6? Are there intermediate steps I have to do?
03-24-2023 12:43 AM
yes correct you do not have .5 OVA, so you need to start with version start OVA and upgrade the patch to .6.
