03-19-2021 01:57 AM - edited 03-22-2021 01:34 AM
Hi!
We have a few CSPC instances that were used for NOS, that we want to keep using for SNTC. We have registered with SNTC and installed the certificate, and the data collection is working fine. However the data upload is failing. We have verified https connectivity to the different URL's (dl1.cisco.com, dl2.cisco.com, sso.cisco.com) from the CLI.
Any help is appreciated.
Edit/amendment March 22:
wget https://concsoweb-prd.cisco.com seems to be working fine
Resolving concsoweb-prd.cisco.com (concsoweb-prd.cisco.com)... 72.163.7.113
Connecting to concsoweb-prd.cisco.com (concsoweb-prd.cisco.com)|72.163.7.113|:443... connected.Resolving cloudsso.cisco.com (cloudsso.cisco.com)... 72.163.4.74, 2001:420:1201:4::b
Connecting to cloudsso.cisco.com (cloudsso.cisco.com)|72.163.4.74|:443... connected.
However, when I try an upload from GUI I can see this in the log (/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out):
2021-03-22 09:16:13,636 ==== thread: qtp668436021-223 ==== INFO >
connectivityteg.uploadFile() => (line: 160)
message: Retry response3,Execute response message:A connectivity exception occured while processing the request. The Exception is :: HTTPs TransportMode has Failed concsoweb-prd.cisco.com: Name or service n
ot known
regards,
Morten
03-22-2021 05:20 AM - edited 03-22-2021 05:23 AM
are these hardware appliance or VMware virtual machine deployed on your own VMware environment? PLease privately send me the Customer name
04-09-2021 10:30 AM
We are having this exact same issue since spinning up a new virtual appliance on 2.9 code. I'm also unable to delete the old collector from the total care site.
04-11-2021 10:20 PM - edited 04-11-2021 10:20 PM
I ended up rolling out the SNTC entitlements on clean installs of 2.9, that did the trick. I guess there was some old config that stopped the SNTC uploads from working.
04-14-2021 08:55 AM
mortenso - when you rolled an entirely new one. Does it show all your collectors in the cisco services page and give you the option to remove the old one?
04-14-2021 10:56 PM
Yes, the services page were still showing the old decommissioned collectors, but I was able to remove them by going to Library - Administration - Inventory Deletion.
