Upload Processing with Cisco
wrightj
Using the Solarwinds NCM connector, it shows "Processing with Cisco".  However, in the portal, I show nothing in the upload processing section of SNTC portal.  I've retried this several times with no luck.
6 Replies 6
CC Cisco
Please share company and inventory names for further investigation.
CATALYST CORPORATE FEDERAL CREDIT UNION
Inventory - CCFCU
Thanks for the details. I believe the issue is that solarwinds uploads do not allow you to specify the name of the inventory to upload.
By default, they are processed under the name: "Solarwinds_Default".
In your case, it looks like all you have to do is select this secondary inventory from the inventory selection on the top left of the portal.
Cesar
Okay, I found that.  anyway to get this into the SNTC portal?
Are you not able to select the Solarwinds inventory?
Can you share a screenshot of what your inventory selection options look like?
I found it.  I was pulling up the information under the Smart Advisor section.
I think I'm good now.
Thank you for the help.
