What MIBs and CLI commands are required for SNTC inventory?
mahir.rabbi1
I'm setting up a CSPC to manage devices for SNTC, and was wondering which MIBs and CLI outputs are required to get enough info for us to use the SNTC portal for contract support, etc.
Thanks!
The required MIBs and CLI commands will be different depending on the device types discovered by the CSPC and what data is required to process those devices.   The CSPC will look at only the one's needed for that device type.   For accurate reporting and data in the SNTC Portal, we do require these MIBs for collection.
Thank you,
Jarrett
5 Replies 5
Jarrett Pomeroy
*typo *
Jarrett Pomeroy
The SNTC Security Page can help with your question.
https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/inventory_and_reporting/SNTC-Security.pdf
Please see starting on page 12.
Thank you,
Jarrett
Thanks Jarrett,
Are those default MIBs the required one, or is there a smaller subset that can be used?
Thanks!
Thank you,
Jarrett
great thanks!
