03-16-2018 12:09 PM - edited 03-12-2019 07:42 AM
Hi All!
I tried to upgrade to the latest patch of CSPC (2.7.3.2), at the beginning its status was Downloading. But after a while, I could not access to the Software Upgrade Central in GUI. Obtaining this Error: (Attached)
Solved! Go to Solution.
03-21-2018 11:09 AM
Hi everyone!
Finally it is done! It has upgraded to 2.7.3.2
One last question: Do I have to follow this same steps for other customers collectors?
Thank you for everythinG!
03-16-2018 01:08 PM
03-16-2018 02:45 PM
03-17-2018 11:46 AM
Hey rodahersua,
Can you confirm you have followed the steps here under 'Prerequisites To enable upgrade for versions 2.7.3 and above'. The proper IPs/Hostnames must be added and deleted for proper connection to be ensured.
Justin
03-20-2018 10:08 AM
Hi again!
At first I did not cover the prerequisites (Hostnames and IPs).
But now it is all done as the document depicts, but I still have the same Error.
03-20-2018 12:51 PM
Hey rodahersua,
Upgrading via CLI after taking care of the Hostnames/IPs gives you the same error still as well? To confirm, you have taken out 72.163.4.161 www.cisco.com and entered 72.163.4.74 cloudsso1.cisco.com, 173.37.144.211 cloudsso2.cisco.com, and 173.38.127.38 cloudsso3.cisco.com into the /etc/hosts file?
Can you run the below command and screenshot the output?
#show download
Justin
03-20-2018 01:59 PM
Hi!
Yep, same error. Here I attach the evidence..
03-20-2018 02:24 PM - edited 03-22-2018 05:31 AM
03-20-2018 02:58 PM
03-21-2018 10:42 AM
Hello were you able to perform the steps I sent you in private note
03-21-2018 11:09 AM
Hi everyone!
03-21-2018 11:46 AM - edited 03-21-2018 11:52 AM
Unfortunately it may not be a universal step it will have various conditions in dependency it may be however be very similar. I am glad I was able to help you. if new problem occur lets us know to confirm
the steps we used but for your SP in specific was similar to the one described on the document referenced on the release notes ( CSPC upgrade guide)
03-22-2018 04:38 AM
What was the solution in this case?
03-22-2018 05:24 AM - edited 03-24-2018 09:35 AM
Hello evanswee I see you have a post I will will work with you on that post in essence we performed a manual upgrade from root here. I will verify the data on your post and see if the process applied here can be applied to your collector https://supportforums.cisco.com/t5/smart-net-total-care-portal-and/cspc-upgrade-from-2-7-3-to-2-7-3-2-stuck-in-downloading/m-p/3351673#M7205
