Export to File with CSPC
smartnet
I have only been able to get the CSPC to upload to Cisco a couple of times in the past 6 months.  Scheduling does not work it seems and it the system keeps saying successful.
Is there a way to download the file manually so I can do a manual import into SNTC?
Lynden Price
Transport File Import
Log into the collector using the username “admin
Run the command
pwdreset collectorlogin 180
Record the password generated
Run the command
pwdreset root 180
SSH into the collector using the username “collectorlogin” and the previously generated password
Run the command
su –
At the prompt, enter the password generated for root
Run the command
cd $CSPCHOME/uploaddata
Run the command
ls –la
Run the command
cd [UploadProfileName]
where [UploadProfileName] is the name you see listed from the previous command (it should match whatever you called your upload profile)
Run the command
ls –la
Find the latest folder by looking at the timestamp.
Run the command
cd [folder]
where [folder] is the latest folder.
Run the command
ls –la
Find the latest transport file by looking at the timestamps
Run the command
cp [filename] /home/collectorlogin
where [filename] is the latest file.
Please see the attached document for an example of the above steps.
Open a file transfer program (such as WinSCP) and log into the collector with the username “collectorlogin”
You should now be able to download the transport file from the collector to your computer.
Go to the portal and use the file import feature under Library > Administration.
Lynden
Lynden Price
Run the command
Run the command
pwdreset root 180
Run the command
su –
Run the command
Run the command
ls –la
Run the command
Run the command
ls –la
Run the command
cd [folder]
Run the command
ls –la
Run the command
Lynden
For versions 2.7 and above use the following document
