03-25-2019 03:05 PM
java.net.ConnectException: Connection refused (Connection refused) at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at java.net.Socket.connect(Socket.java:538) at java.net.Socket.<init>(Socket.java:434) at java.net.Socket.<init>(Socket.java:244) at com.cisco.ca.ss.lcm.adminshell.client.ShellClient.main(ShellClient.java:51) Error occured: could not connect to the database server. Please make sure mysql database server is up and running.
Solved! Go to Solution.
04-22-2019 02:27 PM - edited 04-22-2019 03:05 PM
EDIT
This issue has gone away and is no longer present. Please close this thread. Thanks for the assistance.
03-25-2019 04:38 PM
03-26-2019 11:24 AM
@jofrumki wrote:
The error you are seeing has no relation to the previous post. Do you have access to the Linux users 'collectorlogin' or 'root'?
Yes, I have access to both.
03-26-2019 11:52 AM
03-27-2019 09:39 PM
[root@USCSPC27 collectorlogin]# service adminshell restart Stopping Adminshell server: [ OK ] Stopping Derby DB: [ OK ] Starting Derby DB: [ OK ] Starting Adminshell server: [ OK ] [root@USCSPC27 collectorlogin]#
I was able to successfully restart adminshell, but I still see the same exact errors as in my original post when trying to login as admin.
EDIT
