SNTC collector error UPLOAD_TO_BACKEND failed
Ent.Support1
   We are having issues with our collector pushing data up to the portal. Please let us know if you have any ideas on how to troubleshoot this issue.
6 Replies 6
Lynden Price
I'd be happy to help. What happens when you try to push an upload? Are you getting a specific error?
Lynden
graham.kirtley
Initially I'd suggest that you take a look at the 'view job log details' for the 'upload job' via the GUI; else via the CLI, see what is being written into the log and error files under:
/opt/cisco/ss/adminshell/applications/CSPC/data/commgr/logs
CP run completed for COMPLEX on (172.30.200.245) at Mon Jun 20 12:59:48 UTC 2016 --> Time take:0 sec
Unable to send the profile results to the Cisco Backend. Reason:peer not authenticated
Ent.Support1
This is the error I see in the logs.
Have you enabled the access through your firewall to the Cisco destination server?
Port Requirements (required for upload to Cisco)
  • 72.163.7.113 (TCP 443) concsoweb-prd.cisco.com
  • 72.163.4.161 (TCP 443/80) www.cisco.com
  • 72.163.7.60 (TCP 443/80) dl.cisco.com
  • 72.163.7.60 (TCP 443/80) dl1.cisco.com
  • 173.37.146.12 (TCP 443/80) dl2.cisco.com
  • 173.37.144.208 (TCP 443/80) sso.cisco.com
Also, check out my blog to see some other common issues:
https://supportforums.cisco.com/blog/12987426/self-service-onboarding-where-my-upload-cspc-collector-troubleshooting
Lynden
Thank you Lynden!! I will have the customer check Firewall settings
