Unable to configure TACACS+ server on CSP Collector
Hi, community.
I'm trying to configure a TACACS+ serer on my CSP collector and I'm unable to configure this server from Delegate Admin user. The CSP shows me a "authorization failed" message.
I need someone to help me with this case.
Thank you so much in advance.
Justin Sprake
It sounds as though the CSPC is able to communicate with your TACACS server since the response authorization failed. Can you confirm the Authentication method between the CSPC and your TACACs server via Admin > Manage Remote Authentication Servers?
Justin thanks for your revert.
Where I Can check in CSPC to confirm whether my CSPC is currently configured to use the default TACACs port . In same setting where its testing i also used port 1812 , 49.
My apologies, I've corrected my original post. Can you confirm the Authentication method between the CSPC and your TACACs server via Admin > Manage Remote Authentication Servers?
Hi, I'm facing the same issue. May I know if you fixed this issue and how? Thanks!
