Update to 2.7.3.2 stuck in "Apply in-progress"
Current version: 2.7.3.1
When I tried to upgrade the software to 2.7.3.2 the upgrade process is stuck in "Apply in-progress"
Can someone help with this?
Jarrett Pomeroy
Hello Avinash,
Can you please see if starting the upgrade process again helps it to complete this time? From the "admin" CLI username, you can run the "apply patchfile" command to start the process over.
Thank you,
Jarrett
Hi Jarrett
Thanks for replying.
I get a error. Here is the output
admin# apply sp-30.0.3-2-0-lnx64
Do you want to continue [y|n]? y
execute % Error occured while executing command
Hello Avinash,
Can you please see if running the steps in the section "Known Issue" of the latest Release notes helps to resolve the error you're seeing?  After running the steps, we will need to restart the patching process.
The Release notes are available here.
Thank you,
Jarrett
