Storage Networking
Hello Team,I am migrating from MDS 9148S to MDS 9148T, I have included a part of Zoneset output below and I can see a unique fcid though, but same WWPN is listed under each zone, please can you explain the logic here.This output is from MDS9148S, I a...
My InfoSec team is complaining that my MDS9250i's with version 8.4(2c) are allowing weak encryption standards.My research seems to indicate the standard command to fix this is 'ip ssh ...' in config mode, but this command does not exist on my switch:...
twielgos by Level 1
  • 555 Views
  • 4 replies
I can see Active Zoneset with the command show zone status vsan or show zoneset active, the hosts are connected and there is FLOGI, but when I run the command “show zone alaysis vsan” I do not see any Zonesets listed, can I ignore, should I create a ...
MDS9396S was migrated to MDS9396T successfully, the zonesets are detected under Show zone status, but not under Show zone analaysys. copy zone or zone import commands are no more available, please advise.
I am migrating from 9396S to 9396T through ISL based migration, 9396S (OLD SWITCH) has Enhanced zone set with valid zones,Question is, I shall set Enhanced zone on 9396T, but the warning below is confusing, if I continue, doesn't the empty zoneset ge...
