Can SG-350 enough performance for run Rapid-PVST+ ?
Ethan and Mia
Hello I am not sure , Can sg3xx run Rapid-PVST+ , Rapid-PVST use high resource
Jitendra Kumar
Layer 2 Switching
Spanning Tree Protocol
Standard 802.1d Spanning Tree support
Fast convergence using 802.1w (Rapid Spanning Tree [RSTP]), enabled by default
8 instances are supported
Multiple Spanning Tree instances using 802.1s (MSTP)
Jitendra
Martin Aleksandrov
Hello Ethan and Mia,
Starting with firmware release 2.5.0.79 for Sx350 series switches in addition to STP, RSTP, and MSTP, the device supports PVST+ and RPVST+. PVST+ and /RPVST+ run in separate instances of the 802.1Q STP per VLAN. Rapid PVST runs in a separate instance of the 802.1Q RSTP per VLAN. The device supports up to 126 PVST/RPVST instances. There are no known or expected performance issues related to when the RPVST+ protocol on the switch is enabled.
