CBS 250 - no private VLAN support?
Hubsi-Smith
I am now a bit confused about the private VLAN support for Cisco CBS250 series. I got some of the 250-8T and 250-24T and I could not find the private VLAN configuration as descripted in this document:
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-250-ag/vlan-management.html
Firmware version: 3.0.0.69
In my opinion, there is no private VLAN support but that would be bad. We bought a lot of them for using this feature
Could someone clarify
Best regards
 - It seems that only the cbs350 can do this (private vlans) , I looked it up in the datasheet , where it was mentioned for the 350 but not for  the 250. I further confirmed this by using the online emulators : which can be found in https://community.cisco.com/t5/small- business-online-device/bd-p/911-discussions-online-device-emulators   , you can easily launch one for the 350 and one for the 250 and  easily see that the feature is not available on the 250 (advanced menu). I would suggest to confirm these findings with cisco , or  reseller where you bought it from. Sometimes a deal can be made for swapping. The problem being that the documentation sometimes  does not differ enough between these models
 M.
5 Replies 5
marce1000
 - Post screenshot according to manual : you mentioned , when starting from - see below  (what do you see in your case) ?
  Procedure
Step 1
Click VLAN Management > Private VLAN Settings.
Step 2
Click Add.
there is not link "Private VLAN Settings". Setting from Basic to Advanced didn´t change something
 M.
Thank you for your informations. I will check out my possibilities with our reseller.
