02-13-2022 11:36 PM
I am now a bit confused about the private VLAN support for Cisco CBS250 series. I got some of the 250-8T and 250-24T and I could not find the private VLAN configuration as descripted in this document:
Firmware version: 3.0.0.69
In my opinion, there is no private VLAN support but that would be bad. We bought a lot of them for using this feature
Could someone clarify
Best regards
Solved! Go to Solution.
02-14-2022 07:47 AM
- It seems that only the cbs350 can do this (private vlans) , I looked it up in the datasheet , where it was mentioned for the 350 but not for the 250. I further confirmed this by using the online emulators : which can be found in https://community.cisco.com/t5/small- business-online-device/bd-p/911-discussions-online-device-emulators , you can easily launch one for the 350 and one for the 250 and easily see that the feature is not available on the 250 (advanced menu). I would suggest to confirm these findings with cisco , or reseller where you bought it from. Sometimes a deal can be made for swapping. The problem being that the documentation sometimes does not differ enough between these models
M.
02-14-2022 02:54 AM
- Post screenshot according to manual : you mentioned , when starting from - see below (what do you see in your case) ?
Procedure
Step 1 |
Click VLAN Management > Private VLAN Settings. |
Step 2 |
Click Add. |
02-14-2022 04:56 AM
there is not link "Private VLAN Settings". Setting from Basic to Advanced didn´t change something
02-14-2022 05:12 AM
02-14-2022 07:47 AM
M.
02-15-2022 12:07 AM
Thank you for your informations. I will check out my possibilities with our reseller.
