cisco 300 sf300-48pp switch console access issue
jawharcisco
Hii..
i am unable to access the subjected switch through console ,i have tried all the possible baud rate and different console cables as well .
Please let me know is there any way to solve the issue .
Regards ,
Jawhar.
Brandon Svec
Level 7
Level 7
Are you using the included console cable?  What are you connecting the other end to?  Can you connect to other switches or devices with same cable and software?
The correct settings for your terminal software are here: http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
-- please remember to rate and mark answered helpful posts --
Thanks Brandon !! .i am using not included console cable and this cable and software is fine to access another switches .
And let me go trough the PDF and update you the status .
Jawhar.
