Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Buisness Switch SG300-28P 28
codeman2500
Good evening everyone I am in need of some help, please. I have an SG300-28P 28 switch and I need to copy the configuration files from the switch to my Pc but I am having trouble finding any information on how to do it or what the commands are for this switch. I know this is an old switch but it works great still.
Cody
 Use the web interface which is much more easy.
Go to Administration > Download/Backup Configuration/Log
What would you recommend for transfer method TFTP,SCP? I tried downloading TFTP server it saw it but than it timed out. I have attached screenshot of my screen.
@codeman2500 select transfer method> http/https, then save action > backup, then select running configuration and click apply. then backup file will be download via your browser
Good luck
KB
