11-07-2018 10:06 AM
I picked up a used SG200-08 recently and have added it to a small environment. I wrote a script to gather statistics by 'curl'ing through some of the administrative web pages (output in Nagios format) because the switch does not support SNMP.
I'm tracking the basic stuff - CPU, memory, and interface statistics.
Interestingly, the switch appears to have a memory leak, and I suspect that it's caused by the logins to the http server every five minutes. Looks like it's chewing up about 400kB/day.
There's another post here (https://community.cisco.com/t5/small-business-switches/sg200-08-http-server-memory-leak/td-p/2598334) that noticed the same thing, with no resolution.
Is this a known issue? Is there any possibility that this will get fixed?
11-07-2018 06:10 PM
I am not much familiar with this version of the switch. My advice to book a ticket with TAC team.
Deepak Kumar
11-08-2018 10:39 AM
Deepak Kumar
Thanks for your reply, but that's not very helpful. Since I indicated that I picked up the switch *used*, there's no support contract, so I have no ability to open a TAC case.
11-08-2018 11:59 AM
11-08-2018 02:17 PM
did you check the resources uses after stopping the script?
Deepak Kumar
Yes - if I stop the script, resources no longer decrease.
Currently, the script runs every five minutes. If I run the script constantly (it takes a few seconds to run), memory dwindles dramatically.
11-09-2018 06:56 AM
What is Switch's firmware version? Try to upgrade the firmware.
Deepak Kumar
11-09-2018 08:29 AM
09-06-2022 06:42 AM
@davegrabowould you share your curls or monitoring scripts with us?
09-06-2022 08:20 PM - edited 09-06-2022 08:30 PM
To be clear... I gave up on the SG200, and replaced it with a cheap-on-ebay SG250. I simply didn't have the patience to deal with the SG200.
But, I did write a script that seemed to work. Have fun. (It didn't paste correctly with indents, but I think you can figure it out)
#! /bin/bash
# Obtain statistics for Cisco SG200 and output as standard Nagios plugin
# Grabo 2018-11-04; updated 2019-01-18
# usage: sg200.sh -d=[device] -u=[username] -p=[password]
#bail on any error
set -e
for i in "$@"
do
case $i in
-d=*)
device="${i#*=}"
shift
-u=*)
username="${i#*=}"
shift
-p=*)
passraw="${i#*=}"
shift
esac
done
password=$(echo -n $passraw | base64) #need to convert password to base64
base=$(mktemp -u).sg200.$device #suitable temp file storage
#login and get cookies
curl -s -c $base.cookies -d "uname=$username&pwd2=$password" http://$device/nikola_login.html -o /dev/null
#bail if we didn't get cookies
if [ ! -f $base.cookies ]; then
exit 1
fi
#from this point forward, no error checking, fingers crossed
# basics - hostname and uptime
curl -s -b $base.cookies http://$device/SetupSystemSummary.html -o $base.summary
# hostname
output="sg200|hostname="$(grep NAME=v_1_5_1 $base.summary | cut -d '"' -f2)
# uptime
output+=" sysUpTime="$(grep v_1_2_2 $base.summary | cut -d '"' -f2 | awk '{print 100*($1*86400+$3*3600+$5*60+$7)}')
# cpu and memory
curl -s -b $base.cookies http://$device/DiagnosticsCPUUtilization.html -o $base.diag
# cpu 1min
output+=" cpu1min="$(grep -i v_1_5_1 $base.diag | cut -d '"' -f2)
# cpu 5min
output+=" cpu5min="$(grep -i v_1_6_1 $base.diag | cut -d '"' -f2)
# free mem
output+=" freemem="$(grep -i v_1_9_1 $base.diag | cut -d '"' -f2)
# alloc mem
output+=" allocmem="$(grep -i v_1_8_1 $base.diag | cut -d '"' -f2)
#interface stats
for i in 1 2 3 4 5 8
do
curl -s -b $base.cookies -d "v_1_23_1=g$i&submit_target=StatisticsInterface.html" http://$device/StatisticsInterface.html/a1 -o $base.g$i
output+=" g"$i"tx="$(grep v_1_12_1 $base.g$i | cut -d '"' -f2)
output+=" g"$i"rx="$(grep v_1_3_1 $base.g$i | cut -d '"' -f2)
done
echo $output
#logout
curl -s -b $base.cookies -d "language_selector_withAddOption=en-US&err_flag=0&err_msg=&mainpage=nikola_main.html&loginpage=nikola_login.html&submit_flag=8" http://$device/nikola_main.html -o /dev/null
rm -f $base.*
