Cisco SG300 and LLDP with Yealink Phones.
thermel31
I am currently trying to setup a Cisco SG300 switch with a hosted VoIP solution using the SG300's at the customer's premise. The Yealink phones I am not able to get them to pull an IP address and believe the problem is related to LLDP. We also use Polycom phones and they work just fine. Here is the configuration that I am currently using ( I have tried several different configurations and none of them work with the Yealinks. Any help would be greatly appreciated.
DLC#show run
config-file-header
DLC
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2,88
exit
voice vlan id 88
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname DLC
interface vlan 2
 name Data
interface vlan 88
 name FlexVoice
interface gigabitethernet1
 switchport trunk allowed vlan add 88
 switchport trunk native vlan 2
 no macro auto smartport
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet27
 switchport mode access
 switchport access untagged vlan 2
interface gigabitethernet28
 switchport access untagged vlan 88
exit
DLC#
5 Replies 5
Brandon Svec
Level 7
Level 7
I think no macro auto smartport is preventing the phones from getting voice VLAN assignment.
-- please remember to rate and mark answered helpful posts --
V K Moorthy
You need to add the Yealink phones OUI into voice Telephony oui-table:
Refer from page:211(use the below link)
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
I have attached the GUI options also
regards
Moorthy
Here is the latest configuration that I tried, Polycom phone worked, Yealink didn't.
co-test#show run
config-file-header
co-test
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 2,88,881
exit
voice vlan id 88
voice vlan state oui-enabled
voice vlan cos 6 remark
voice vlan oui-table add 0004f2 Polycom
voice vlan oui-table add 001565 Yealink
hostname co-test
interface vlan 2
 name data
interface vlan 88
 name flexvoice
 ip address 172.16.88.2 255.255.255.0
 no ip address dhcp
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 voice vlan enable
 switchport access vlan 2
 switchport access vlan 88
exit
co-test#
Do you know how your Polycom phones get their voice VLAN? OUI, CDP, LLDP, hard coded?
I can tell you that if you default this switch and enter command: voice vlan id 88
then plug in a default Yealink phone it will get voice VLAN via LLDP and the switch port will be auto configured via smartport macro.
Hi Thermel31,
I have no Yealink in my lab but I have seen such an issue before. I know that for OUI voice vlan LLDP is needed but somehow Yealink LLDP does not really help and phone stays in the data vlan. I would recommend you to open ticket with Cisco Small Business Support team:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
