03-29-2023 01:42 AM
Dear Team,
Please guide how to configure below type of configuration.
How to set vlan under the interface after stack configuration and what will be configuration on CBS-48T switches.
Please guide.
Solved! Go to Solution.
03-29-2023 02:12 AM
You will likely need:
03-29-2023 02:12 AM
03-29-2023 02:23 AM
Sir, yes i will do the Port channel on copper interface caused its no of 8 access switches. do you any reference link and documents for the configuration, also core switches is in HA mode ..
03-29-2023 02:33 AM
The core switches need to be a stack (HA) to be able to span a port-channel over both member switches. You should be able to find all you need in the administration guide:
If you run into problems, just come back with your questions.
