SG100D-08 DHCP issue
impaelas
5 Replies 5
impaelas
Having issues with the forum on Brave so here goes.
I have a Huawei modem/router that serves as a DHCP. To expand wired network I've plugged in SG100D-08 with a Cat5 cable.
The problem is that IP addresses are not being assigned to devices connected via SG100D-08. Only one will receive an IP address and the rest remain disconnected.
Any ideas what might be the reason?
Thank you,
Imp
 - Note https://www.cisco.com/c/en/us/obsolete/switches/cisco-small-business-100-series-unmanaged-switches.html , it would advisable to 'support your business' with more recent devices : https://www.cisco.com/c/en/us/solutions/small-business/selector-tool.html
 M.
Thx but I have this brand new and laying around. It should do more than fine to hook a set top box and a pc i believe.
SG100D-08  - is a just dumb switch / you need to look at your Huawei side what is the config on the port that is connected to the switch, and see any security settings.
BB
Thx, aware of that which is why it's puzzling me. DHCP is on, tried setting static IP addresses via MAC but to no avail.
