Cisco Small Business
sachinc01
Dear Team,
Please guide how to configure below type of configuration.
How to set vlan under the interface after stack configuration and what will be configuration on CBS-48T switches.
Please guide.
You will likely need:
  • One port channel on each access-switch with member interfaces to both core-switches.
  • On the core you have four port channel to each access-switch with member interfaces from both cores.
  • All port channels are configured as trunk
  • Hopefully the access-switches are nearby as you don't have enough SFP ports on the core to connect them with fibre.
sachinc01
Sir, yes i will do  the Port channel on copper interface caused its no of 8 access switches. do you any reference link and documents for the configuration, also core switches is in HA mode ..
The core switches need to be a stack (HA) to be able to span a port-channel over both member switches. You should be able to find all you need in the administration guide:
If you run into problems, just come back with your questions.
