CISCO SMB switch part number required
shuvra.debnath
Dear team,
good day,
I have a query related cisco unmanaged 10/100 switch with the following criteria below and give me the part number for the followings
1. cisco 8 port unmanaged 10/100 all 8 port POE switch
2. cisco 16 port unmanaged 10/100 all 16 port POE switch
addition** if there is any model that has (8 port poe+1 extra port to connect with DVR/NVR, also for 16 port poe+1 extra port to connect with DVR/NVR)
those switches will connect with IP camera
Thanks in advance
Shuvro Debnath
System engineer
2 Accepted Solutions
Data Sheet are here:
https://www.cisco.com/c/en/us/products/collateral/switches/110-series-unmanaged-switches/datasheet-c78-734450.html
This is the table related to PoE ports:
Power over Ethernet (PoE)
Model Name
SF110D-08HP
SF110D-16HP
SG110D-08HP
SG110-16HP
SG110-24HP
Power Dedicated to PoE
32 watts
64 watts
32 watts
64 watts
100 watts
Number of PoE Ports
12
If you need more PoE ports you can check for 250 Series Switches but they are managed.
Data sheet is here:
https://www.cisco.com/c/en/us/products/collateral/switches/250-series-smart-switches/datasheet-c78-737061.html
Or 2960 switch:
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/models-comparison.html
Otherwise you can check for Linksys switch:
https://www.linksys.com/gb/c/business-network-switches/
Regards.
6 Replies 6
Hi, check the link below:
https://www.cisco.com/c/en/us/products/switches/110-series-unmanaged-switches/models-comparison.html
You can find a list of unmanged switch.
Regards.
Hi Daniele,
Thank you so much for the reply
Also can you please suggest me which of them are all port POE, because I am not finding any clue
I have searched different datasheets that says for 8 port switch 4 of them are poe and rest of them are non poe.
TIA
Model Name
SF110D-08HP
SF110D-16HP
SG110D-08HP
SG110-16HP
SG110-24HP
32 watts
64 watts
32 watts
64 watts
100 watts
Number of PoE Ports
12
Data sheet is here:
Or 2960 switch:
Regards.
Hi Daniele,
Thanks for the quick response and your support
with the reference with your table regarding POE ports, my question is there any model that has all ports poe? like "Model"-08HP that has 8 port poe!
if not then suggest me the solution in this regards and there is no option to go with linksys also no option for managed and higher model, because the purpose is to connect surveillance system.
110 series switch have only the half of ports poe.
If you need full ports poe you must switch to 250 series switch. In this case all ports are poe but you must check the power budget:
"the switches support 802.3at PoE+, 802.3af, and Cisco prestandard (legacy) PoE. Maximum power of 30.0W to any 10/100 or Gigabit Ethernet port, until the PoE budget for the switch is reached."
Check the link in the previous post to see datasheet.
Otherwise you can use 2960 switch:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html
250 series switch and 2960 switch are managed but they work also without configuration in default mode.
Regards.
Thanks for the information
I am working on it, I will let you know if any guidance required
Shuvro
