Ciso Access Layer swtich
rsrikant
I have the below requirement.
I have a Windows 10 Physical PC & inside the PC I do have a windows10 Virtual VM.
I want to connect the Physical PC to the network access layer switch port.
Requirement is that the Physical PC & the virtual PC should get IP address from different VLAN.
Let me know if this is possible. If possible let me know what configurations are required in the network access layer switch.
8 Replies 8
balaji.bandi
If PC have have dual NICs (or USB to Ethernet adapter available in the market for cheap price), differentiate with 2 networks or VLANs.
BB
fbabashahi
Hi as i know you can't connect 2 normal vlan to a port , you should use a port with sub interface each sub interface is for a vlan (i don't test myself , if it is possible may be you can make port trunk but it is not safe)
another solution that i am not completely sure in your scenario is private on a access port
johnd2310
Level 8
Level 8
If the network card in the PC supports vlans, you should be able to configure vlans on the PC and connect to different networks. Check the drivers for your network card. On the switch you will need to configure the port to the PC as a trunk with the requisite vlans.
John
**Please rate posts you find helpful**
Let me know what configurations needed to be done in PC.
Any reference or document which shows what configurations needed to be done ?
Look at the example Intel network card have support VLAN (attached image for reference)
BB
I tried it with the updated NIC driver.
but still not able to enter VLAN
Let me know any way to achieve this.
What network card you have?
John
Your nic already bound to vNIC, so unbind and start doing again.
BB
