CLI command to find the temperature on CSS11503
Chandra Shekar Mannem
Experts,
Appreciate your quick assistance here.
My Customer is working on optimizing the environmental conditions at all his Data Center locations (Currently they are in the range 68F to 74F at their locations and they want to increase the temp to 76F) . So, the customer wants to know the standard low / average / high thresholds of CSS11503 switches that they have in their Data Center locations and the current readings of these switches in their network just to make sure so that they don't raise the temperate in the hot location and end up having platforms shut down because the temperate was raised without confirming the platform and ambient temperature.
After doing some research in CCO, I found this below link which talks about the Ambient Operating temperature.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.10/installation/guide/Install.html
Temperature:
•Ambient operating temperature is 32° to 104°F (0 to 40°C)
I am trying to find the CLI show command that I can use to get the current readings, but I couldn’t find the show environment temperature command on the customer's production switch.  In my opinion, “show environment temperature” command is kind of a standard command which should be on the switch irrespective of the code that it is running. But for some reason, I couldn’t find it on the production box. Is there any other related CLI show command that gives me this information that I am looking for? I also tried to find the “show diag environment” from the support forum on the production box, but no luck even with this.
https://supportforums.cisco.com/thread/152884
Here is the production box,
#show  version
Version:               sg0820201 (08.20.2.01)
Flash (Locked):        08.10.0.02
Flash (Operational):   08.20.2.01
Type:                  PRIMARY
Licensed Cmd Set(s):   Standard Feature Set
#show ?
  1                   Show slot
  0                   Show slot
  acl                 Show Access Controls Lists
  aliases             Show alias commands
  app                 Show APP information
  app-udp             Show APP-UDP information
  archive             Show Archive directory or an individual archive file
  arp                 Show ARP information
  boot-config         Show the system boot configuration
  bridge              Show Bridging information
  cdp                 Show information about cdp advertisement
  chassis             Show chassis configuration
  circuits            Show circuit information
  clock               Show current date and time
  cmd-sched           Show command scheduler information
  content             Show current entries in the content service database
  core                Show system Core files
  critical-reporters  Show critical-reporters information
  critical-services   Show critical-services information
  dfp                 Show DFP Agent information
  dfp-reports         Show Weight Reported by DFP Agent
  dhcp-relay-agent    Show DHCP Relay Agent information
  disk                Show disk information
  dns-boomerang       Display Content Routing statistics
  dns-peer            Show DNS Peering information
  dns-record          Show DNS record information
  dns-server          Show DNS Server information
  domain              Show content domain summary information
  dormant             Show redundant flow information
  dos                 Display Denial of Service (DOS) statistics
  dql                 Show Domain Qualifier Lists
  dump-status         Show system dump status
  eql                 Show Extension Qualifier Lists
  ether-errors        Show RFC1398 extended Statistics
  ether-errors-32     Show RFC1398 Statistics
  flow-state-table    Show Flow-State configuration table
  flow-timeout        Display flow-timeout values.
  flows               Show flow summary information
  global-portmap      Show SFP global portmap info
  group               Show group information
  gsdb-interface      Show GSDB interface information
  header-field-group  Show configured Header-Field-Group List
  history             Show the session command history
  http-methods        Show HTTP supported methods
  http-redirect-opt.. Show SFP http-redirect-option info
  installed-software  Show currently installed software
  interface           Show interface information
  inventory           Show UDI inventory
  ip                  Show IP information
  ip-fragment-stats   Show IP fragment statistics
  isc-ports           Show configured Inter-Switch Communication Ports.
  keepalive           Show Keepalives
  keepalive-summary   Show summary info on all keepalives
  lines               Show currently connected lines
  load                Show global load information
  log                 Send log activity to this session or display an individual
                      log file
  log-list            Show log directory
  log-state           Show the state of active logging
  map                 Show MSD mapping
  mibii               Show MIBII extended information
  mibii-32            Show MIBII information
  noflow-portmap      Show SFP noflow portmap info
  nql                 Show Network Qualifier Lists
  ospf                Show OSPF information
  owner               Show owner configuration information
  phy                 Show PHY information
  profile             Show the running user profile
  proximity           Show proximity information
  publisher           Show publisher information
  radius              Show radius information
  redundancy          Show information about box-box redundancy
  redundant-interfa.. Show redundant-interface information
  redundant-vips      Show redundant-vip information
  remap               Show SFP remap info
  reporter            Show reporter information
  rip                 Show RIP information
  rmon                Show RMON extended statistics
  rmon-32             Show RMON statistics
  rmon-history        Show RMON history
  rule                Show content rule information
  rule-summary        Show content rule summary information
  running-config      Show the running configuration
  sasp                Show SASP information
  sasp-agent          Show detailed information for a sasp-agent
  sasp-agent-summary  Show a summary of the SASP Agents
  script              Show script directory or an individual script
  service             Show service information
  session-redundant   Show session redundancy configuration
  setspan             Show configured SPAN settings.
  sntp                Show SNTP information
  sockets             Show a status of all open sockets
  sshd                Show SSHD information
  ssl                 Show commands for SSL
  ssl-proxy-list      Show SSL Proxy Lists
  startup-config      Show the startup configuration
  startup-errors      Show errors occuring during startup configuration
  sticky-stats        Show sticky connection statistics
  sticky-table        Show sticky information
  subscriber          Show subscriber information
  summary             Show owner summary information
  system-resources    Show system-resources
  tacacs-server       Show TACACS+ server information
  trunk               Trunking table
  uptime              Show the uptime of the unit
  urql                Show Url Qualifier Lists
  user-database       Show configured users
  variable            Show user Variable(s)
  version             Show the current software version
  virtual-routers     Show virtual router information
  zone                Show PCM zone information
Appreciate your quick response.
Shekar
viningele
Level 3
Level 3
On my SG500-28 I found this command:SG500-28-1#show environment temperature status
but it returns N/A and I don't see a temp on the web gui either but maybe you'll have better luck if this works on your switch.
Joachim Buechse
show system
provides the FAN status and (internal) temperature or our SG500 switches.
Michal Bruncko
Level 4
Level 4
this is pretty old request already, but... ok.
this command works:
css# llama
css(debug)# show temperature all
the temperature info is hidden into special debug mode of CSS unit. Command output shows temperature based on slot ("all" for showing all slots). example:
Slot 1 Temperature - 34 degrees C.
Slot 2 is not populated.
Slot 3 is not populated.
Slot 4 Temperature - 32 degrees C.
I have sg300-28 without fan.  On motherboard I see that I can solder plug and connect fan. But In GUI I don't have option Health. Is any chance to activate it and mode cisco without fan and temp to version with fan and temp showing in GUI in HEALTH?
