Get device temperature via CLI on SG300-28PP
Joerg -
Good morning,
according to the CLI manual, release 1.4, page 980 ff. there is a "show environment" command similar to regular Cisco switches. When typing this command in the CLI there's a "Unrecognized command" error message.
Is there any way to get a read on the temperature via CLI, SNMP, ...?
Joerg
7 Replies 7
Mark Malone
what options does it give you in cli , use ? mark see whats available
show e ?
or try show power
show e
eee                    Energy Efficient Ethernet
errdisable           Show errdisable state.
sh power shows the temperature of the PSU
strange doc says its there but not , maybe check your on the latest 1.4 release  sx300_fw-1476.ros
Double checked: I'm on 1.4.7.6
I looked into the CiscoSB-Mibs and found only the PSU temp (OID .1.3.6.1.4.1.9.6.1.101.108.3.1.6.1) and the Temp status (OID .1.3.6.1.4.1.9.6.1.101.53.15.1.13.1).
Could get these infos via snmpget. So it's not the solution I was hoping for but better than nothing at all.
Thanks a lot for your help.
ksbolton1
show system does this.
example:
FAN is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 23 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 51 Degree Celsius
Red Threshold : 61 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1 Built-in Good
SW Status RPS Name RPS Serial# RPS Port#
1 <> <>
Try the following commands:
switch# show system sensors
switch# show system fan
Hope it helps
Cheers,
Mike
