Configuration SMTP on Cisco RV345
GBInformatics
Hello everyone,
I am in the process of configuring a Cisco RV345 router. I'm at the SMTP configuration stage but I'm totally blocked.
I put :
SMTP Server: smtp.gmail.com (e.g.: 1.2.3.4 or abc.com or fe80::10)
SMTP Port: 465 or 587 (Range: 1-65535 Default: 25)
Email Encryption: TLS/SSL
Authentication: LOGIN
Username: adresse_gmail
Password: application_password (with and without spaces)
Send Email to 1: adresse_gmail (Email Address)
Send Email to 2: (Email Address (Optional))
From Email Address: adresse_gmail
I get the error: Test SMTP Server ‘smtp.gmail.com’ failed!
Can you please help me?
Translated with DeepL.com (free version)
8 Replies 8
It still doesn't work
balaji.bandi
Try removing 2-factor authentication or adding the app password from Gmail and testing it. I used a Python script to send emails using Gmail, and it works.
If there is an issue, then maybe try a different email provider who can offer these services with plain, simple SMTP to send an email or set your own relay SMTP to send alert emails.
BB
GBInformatics
I already use Google's application password. I think it's a shame that a brand like Cisco doesn't allow you to configure this simply.
GBInformatics
I am following the documentation below
Hello, that's what I did but it doesn't work.
nagrajk1969
Try the below settings/options....the second method may work properly i guess (but it will be not encrypted/secure maybe)
email settings :-
smtp.gmail.com
port: 587
email-encryption: tls
authentication: plain text
user-id
password
sendemail-1/2:
fromemail:
OR
smtp.gmail.com
25
email-encryption: NONE
authentication: LOGIN
USERNAME:<user-id>
password:<your-mailacct-passwd>
sendemail-1/2:
fromemail:
Note: in this case go to gmail-account and say yes or allow access from new connection as above...
hope it helps
regards
I've tested this method with another router of the same model and it works.
SMTP Port: 587
Username: address_gmail
Send Email to 1: address gmail
Send Email to 2:
From Email Address: address gmail
It's OK.
