Does Cisco SBS switchs with SFP+ slots support 1G SFP Modules?
ASBTECH
I want to know if Cisco SBS series switchs with SFP+ slots (like CBS350-24P-4X) supports SFP (1 Gig) modules (dual speed)?
I have some cases where customers already have old Cisco 350X switchs with 1G SFP uplink ports and need to know if using an SFP module on CBS350-24P-4X will work to connect to 1G switchs.
Thanks, in advanced for your help.
Regards.
balaji.bandi
CBS350-24P-4X - on this you can use SFP and SFP+ Module you can install SFP 1G to connect to OLD switches.
BB
balaji.bandi
BB
ASBTECH
Thank you Balaji for your quick response!!
One last question: will this work even when the remote switch is not a Cisco switch but using SFP modules and slots?
sure as long as the wavelength same, does not matter what switch - they should able to establish connection.
BB
ASBTECH
Thank you very much for your help Balaji!
