Exec-timeout command missing
PacNWNetTek
Frequent Visitor
Frequent Visitor
I hope this is a general question and its hard to word the question to search online. Here is my console port config:
line con 0
session-timeout 30
logging synchronous
login authentication CONSOLE
stopbits 1
I am currently unable to console into this switch. The difference i see between this and the multitude of others that work is there is exec-timeout 10 1 it missing, see below:
session-timeout 30
exec-timeout 10 1
logging synchronous
stopbits 1
Would this be the reason why it seems my username and password are correct yet the switch immediately kicks me out?
balaji.bandi
That is for Console (exec-timeout MINUTES SECONDS)
check your SSH connection should be ok, check any VTY likes stucked, show users give you information.
BB
