SMB switches & Vlan ACL/Vlan Access Map
sboudjel
Hi Community,
I didn't find anything about it, so I would like to know if SMB switches supports  Vlan ACL/Vlan Access Map.
Thank you
@sboudjel
Sx110/CBS110 series switches are unmanaged. Sx250/CBS250/Sx350/CBS350/Sx550 do support VLAN ACL binding. You can refer to our online device emulator and see the full feature-set functionalities.
https://community.cisco.com/t5/small-business-online-device/bd-p/911-discussions-online-device-emulators
6 Replies 6
balaji.bandi
Not yet, it is not define.
I just want to know if one of the switches propose this feature.
Thank you for the link, that confirm that Sx350 Series support VLAN ACL. Any idea about the others (SMB110, 250, 1000)
Thank you
@sboudjel
Thanks a lot for your help @Martin Aleksandrov
The tool is also helpful !
you're welcome!
Basically with the online device emulators, one can see all the features our devices support. Switches web GUI covers 100% of the CLI command line functionalities and routers and APs have only web GUI to administer.
Martin
sboudjel
Please anyone else to know if  Vlan ACL/Vlan Access Map is supported on SMB switches products ?
Thank you
