08-16-2013 05:27 AM
Have problem with Dhcp function on SG300 / 500 ? now i can use dhcp server on both model but have a problem.
my problem is when i create
vlan 1 : 192.168.0.1/24 dhcp pool 192.168.0.10-250
vlan 10 : 192.168.10.1/24 dhcp pool 192.168.10.10-250
case 1
i plug pc to vlan 1 i can get ip 192.168.0.11. But when i change this pc to a new port in vlan 2 i still get same ip address. why i can not get ip from vlan2.
case 1
i plug pc to vlan 2 i can get ip 192.168.10.11. But when i change this pc to a new port in vlan 1 i still get same ip address. why i can not get ip from vlan1.
but when i access to the switch and clear binding after that i will get correct IP.
i think this is bug from this firmware. Could you help this case.
Solved! Go to Solution.
09-28-2013 07:07 PM
This is a known bug which Cisco is fixing
08-16-2013 07:49 AM
Hi siriphan, can you post your config file?
-Tom
Please mark answered for helpful posts
09-20-2013 10:41 PM
[BEGIN] 8/14/2013 10:05:23 PM
config-file-header
THR-CSW1
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-6,10
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp excluded-address 172.16.10.1 172.16.10.10
ip dhcp excluded-address 172.16.10.251 172.16.10.254
ip dhcp excluded-address 172.16.20.1 172.16.20.10
ip dhcp excluded-address 172.16.20.251 172.16.20.254
ip dhcp excluded-address 172.16.30.1 172.16.30.10
ip dhcp excluded-address 172.16.30.251 172.16.30.254
ip dhcp excluded-address 172.16.40.1 172.16.40.10
ip dhcp excluded-address 172.16.40.251 172.16.40.254
ip dhcp excluded-address 172.16.50.1 172.16.50.10
ip dhcp excluded-address 172.16.50.251 172.16.50.254
ip dhcp excluded-address 172.16.99.1 172.16.99.20
ip dhcp excluded-address 192.168.0.1 192.168.0.20
ip dhcp excluded-address 192.168.0.251 192.168.0.254
ip dhcp pool network Civil
address low 172.16.50.1 high 172.16.50.254 255.255.255.0
lease infinite
default-router 172.16.50.1
dns-server 172.16.50.10 203.113.24.199 203.113.127.199
exit
ip dhcp pool network Consult
address low 172.16.20.1 high 172.16.20.250 255.255.255.0
lease infinite
default-router 172.16.20.1
exit
ip dhcp pool network Customer
address low 172.16.10.1 high 172.16.10.250 255.255.255.0
lease infinite
default-router 172.16.10.1
exit
ip dhcp pool network MgMT
address low 172.16.99.1 high 172.16.99.254 255.255.255.0
lease infinite
default-router 172.16.99.1
exit
ip dhcp pool network Thaiouihoma
address low 192.168.0.1 high 192.168.0.250 255.255.255.0
lease infinite
default-router 192.168.0.1
exit
ip dhcp pool network Wifi-Guest
address low 172.16.40.1 high 172.16.40.250 255.255.255.0
lease infinite
default-router 172.16.40.1
dns-server 203.113.24.199 203.113.127.199
exit
ip dhcp pool network Wifi-Thaiouihoma
address low 172.16.30.1 high 172.16.30.250 255.255.255.0
lease infinite
default-router 172.16.30.1
exit
bonjour interface range vlan 1
ip access-list extended Block-Guest
deny ip any 172.16.10.0 0.0.0.255
deny ip any 172.16.20.0 0.0.0.255
deny ip any 172.16.40.0 0.0.0.255
permit ip any any
exit
hostname THR-CSW1
username admin password encrypted d1a523896bf0c6c032a0e9bb1e9e9c425afe301b privilege 15
snmp-server location Rayong
snmp-server contact ITsolutions
ip telnet server
interface vlan 1
ip address 172.16.99.1 255.255.255.0
no ip address dhcp
interface vlan 2
name Civil
ip address 172.16.50.1 255.255.255.0
interface vlan 3
name Customer
ip address 172.16.10.1 255.255.255.0
interface vlan 4
name Consult
ip address 172.16.20.1 255.255.255.0
interface vlan 5
name Wifi-Thaiouihoma
ip address 172.16.30.1 255.255.255.0
interface vlan 6
name Wifi-Guest
ip address 172.16.40.1 255.255.255.0
interface vlan 10
name Thaiouihoma
ip address 192.168.0.1 255.255.255.0
interface gigabitethernet1
description Connect->Teaming-NIC-HP-Server
channel-group 1 mode on
service-acl input Block-Guest
switchport mode access
interface gigabitethernet2
interface gigabitethernet3
description Connect->IBM-Server
switchport access vlan 2
interface gigabitethernet4
description Link->AP1
switchport trunk allowed vlan add 2-6,10
interface gigabitethernet5
description Connect->SG200
interface gigabitethernet6
description Coonect->IBM-Server
switchport access vlan 10
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
description Link->AP2
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet28
description Link->Router
interface Port-channel1
description Connect->Server-HP
exit
ip default-gateway 172.16.99.254
THR-CSW1#
it very simple config
if i connect port with pc it can get ip address but when i move that pc to another vlan i still get the same ip so i move the other vlan. i still remember old ip address. i must access to switch and delete arp and ip binding from web interface.
Many thank for kindly support.
09-21-2013 06:13 AM
This is pretty normal behavior. You can lower the arp time out. Otherwise you'd need to wait for the current arp to expire.
-Tom
09-21-2013 10:32 AM
I think it not normal because I use another vlan but I got ip address from the past port. It different.
Sent from Cisco Technical Support Android App
09-21-2013 03:32 PM
No it's not different. A vlan is a layer 2 function and IP is layer 3 function. When your ARP expires you will get the expected IP address.
The solution is lower your ARP time out or let your old ARP expire.
-Tom
09-21-2013 03:52 PM
Apparently the arp and dhcp lease/binding tables are global or common to all vlans and dhcp pools so when you unplug from one port/vlan your mac is still in a table associated to that particuler address and then when you unplug and then plug into another port that's assigned to another vlan/dhcp pool and your pc issues a dhcp request but your still in the table and the switch erronoiusly assumes your bound to the last IP because you're still listed in those tables so that's what you get, the same IP despite the fact you're in a completely different vlan possibly with a different dhcp pool.
Normally a host doesn't dynamically or manually change vlans like you're doing with your pc as you set up and test your network so normally this is a non issue and that's why it's not considered a bug. However I have written programs in the past that do programmatically change a port's access vlan in order to join a particular vlans video multicast group so I do think this is indeed a bug that should be fix even though in most situations its just an annoyance while testing.
09-28-2013 07:07 PM
12-09-2013 04:28 AM
yes now this problem was solve from the lastest firmware.
